can anyone tell me where this ac compressor wire is supposed to go
  • davelikesturtle
    • May 2013
    • 8
    Hey guys im Trying to get my ac together but I have no clue where this goes,and im guessing its to get the clutch to engage?
    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
  • davelikesturtle
    • May 2013
    • 8
    Anyone?:(
    • glucklich21
      • 1912
      Yes
      • davelikesturtle
        • May 2013
        • 8
        Originally posted by glucklich21
        Yes
        Where does it connect to?
        • 101
          • Jul 2011
          • 764
          I'm not exactly sure from your picture. Is that the wiring coming from the compressor to the car or is it coming from the car's wiring harness?
          In any case, there are either one or three wires that go out to the compressor.
          A single wire activates the compresor clutch. The compressor ground is through the bolts that attach it to the engine.
          The other two wires (if you have them) are for a compressor temperature overheat sensor switch. This basically turns off the compressor if it gets too hot. Not all compressors have that feature. Mine doesn't - but I would think it is just wired in series with the compressor clutch wire.
          Hope this helps!
          101
          The E30 collection:
          1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
          1987 325is - Delphin / Black Sport (son #3's)
          1987 325i Convertible - Triple Black
          1989 325iX Coupe - Diamondschwarz / Black Comfort
          1990 325iX Coupe - Sterling Silver / Grey Sport
          1981 Fiat 124 Spider 2000 - Green / Tan
          1998 Volvo V70 GLT - White / Tan
          1998 Volvo S70 T5 manual - White / Taupe
          2001 Ford Windstar - Silver / Grey (parts hauler)
          2006 Lexus GX470 - White / Tan (tow rig)
          • davelikesturtle
            • May 2013
            • 8
            Hope this helps!
            The one in the picture is coming from the compressor. So once I have the compressor mounted on , the clutch should be able to kick in ,correct?
            • 101
              • Jul 2011
              • 764
              correct.
              You can test it in advance by applying a 12V source to the wire and grounding the body of the compressor. If its working properly, the clutch should engage.
              101
              The E30 collection:
