Strange Turn Signal Issue
  • AdamPlaysDrums
    • Apr 2012
    • 140
    My '91 four door has sat for some time now, and I've had an issue with the front left turn signal since I started driving it again. The right side turn signals work just fine, but only the left rear blinks, and it blinks much faster than it should. The left front signal will light up and stay on, but not blink. I assume that it isn't a switch issue as the left rear would most likely not work either. What should I look for next? thanks! :up:
  • dnguyen1963
    • Nov 2011
    • 2651
    I have had this happened to my Toyota many times. You need to replace the bulb and clean the socket well. A bad connection in the socket can cause the light to blink rapidly even when the bulb is good.
