Can a bad battery do other damage or throw other symptoms?
  • Rtheriaque
    • Apr 2013
    • 78
    I have an '89 325i.
    The other day, the car wouldn't start. Dead battery. A quick jump got her running.
    Today, same thing. She had a long run the day before, so it was down to bad battery, fault in the charging system, or a drain.
    I did some tests. Per Bentley, the car should have 13.5-14.2V at the battery with the engine running at 1500 RPM. I got 13.52. As I buttoned up, I noticed the battery was covered in condensation. No rain had touched the car. With a manufacturing date of 4/97, I think the battery was my bingo, but I load tested anyway. It passed easily. Hmmm...
    I threw the new battery from my '73 2002 into the car. I now get 13.7V at the battery with the motor running at 1500 RPM.
    So... I'm leaning toward the E30's battery as being bad. Any other opinions?
  • IRON-E
    • 16548
    Your Alternator could be draining the battery. Take the battery to a local shop, to be tested and charged and go from there.
    @IRON-E30 aka Edwin:D
    • Rtheriaque
      • Apr 2013
      • 78
      Like I said, original battery was load tested and passed. Unlike the alternator check, which barely passed, I got a go/no-go from the battery test. No idea if it was a strong pass or a barely pass.
      The fact the alternator was putting out more juice to one battery than the other feels like a clue to me.
        Put a new battery in and see what happens. It does sound like the one have is bad.
        • george graves
          • 19998
          What's your voltage after sitting overnight on the old battery?
          Originally posted by Matt-B
          • atldohc
            • Nov 2008
            • 359
            if you already have another battery why not throw it in and try starting it again the next morning. then youll know if its the battery or a parasitic draw somewhere
