A/C Low Pressure Switch
  • mcaden
    • Jun 2011
    • 164
    My a/c low pressure switch is bad and I need to replace it. Will unscrewing and removing the low pressure switch vacate the system or is there a valve that prevents the freon from escaping? I was hoping to just unscrew the old one and screw in the new one.
    Thanks, Marc
    Removing the valve will dump the refrigerant.
    • mcaden
      • Jun 2011
      • 164
      Jim,
      Thanks for your quick response - I was afraid that was the answer. Oh well.
      All the best.
      -Marc
      • crazyman
        • Dec 2010
        • 738
        Out of curiosity what makes you think it's bad?
        85 swartz/metallic 325E
        84 alpine 325E
        85 zinnoberot 318i/R.I.P
        84 Bronzit 318i/sold
        purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
        • mcaden
          • Jun 2011
          • 164
          I jumped the wiring to the switch and the wire is hot. However, I tested the switch and its bad and causing the compressor not to turn it. It's fairly easy to test.
