Solved!!!!!
Hello all!! I have a 93 vert with the stock m20b25 in it. My car only has about 112k on it. Recently I have had starting issues. The car will crank over no problem but wont fire. I haven't had a second person around to help me check for spark so that may be the issue but hear me out first because it will start and run.
So far the car has started every time but it is taking a long time(30sec-4min) sometimes and I am getting worried soon it wont start at all. Its more difficult to start when the car is cold and has been sitting. Once it starts it runs and drives perfectly fine. If I shut it off its a 40/60 chance of it starting right back up again.
1.I have read that the temp sensor can fail and cause fuel air mix issues. Is this the case I am having?
2.My Second guess would be that the fuel pump is failing or the relay for the pump. Where are these relays and how can I check them?
3.Are my injectors are clogged?I understand that the issue could be fouled injectors too, which I plan on cleaning tonight.
4.Now yesterday was the first time I have had a new issue and I am not sure if it is related or not. I was stopped just letting the car idle and it suddenly r3ved to about 1800 RPM and then back to idle. It was really odd and out of place. This lead me to think my idle control valve is the problem(but I cleaned it or I have a vaccumm leak? I can Smoke test the car but not until this weekend.
Please help me out guys. Am I looking in the right direction? Has anyone had similar issues in the past?
So far I have replaced the following engine parts. Some may or may not be related to this problem but I figured its worth adding:
-spark plus
-cap and rotor
-timing belt and all the other belts and seals that go along with it
-valve cover gasket
-oil pan gasket
-water pump
-water pump gasket
-thermostat gasket
-thermostat
-fuel filter
-air filter
Any input would be greatly appreciated fellow enthusiasts!
-spark plus
-cap and rotor
-valve cover gasket
-oil pan gasket
-water pump
-water pump gasket
-thermostat gasket
-thermostat
-fuel filter
-air filter
