engine flush after HG replacement
  • jrobie79
    • Mar 2006
    • 2525
    I just replaced my head gasket in my m42, and I used brake cleaner and some purple power to clean the pistons and block of which I'm sure some crept into the oil. I already drained the oil, and I will be changing the new oil out after about 100-200 miles just to have the filter pick up anything I might have missed with the vacuum. Was wondering if people suggested I throw some "engine flush" for the first oil change and any brand recomendations
    1991 318i ---- 308K - retired
    Just change the oil and filter sometime in the next 500 miles.
    • peytonracer4
      • May 2011
      • 524
      and it might not hurt to pull the pan and wipe it really clean after your next oil change in a few hundred miles. on the m42 it's easy enough to do. that'll also allow you to see if you have any plastic pieces from your chain guides in there if you've never serviced that area.
      • jrobie79
        • Mar 2006
        • 2525
        yeah I have a spare lower pan gasket kicking around anyways, might as well. thanks all
