fluid-filled engine mounts
  • MrK
    • Jan 2006
    • 709
    What kind of engine mounts come standard on the e30? And if they are solid rubber, what is the advantage of putting fluid-filled ones instead? I'm looking to isolate the engine vibes from the passenger compartment if possible, cuz the car breakdances at idle practically, which to say the least is not really comfy.
    This is your M20 on steroids:
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Never heard of any fluid filled engine mounts for the E30. The OEM ones are vulcanized rubber.
    Sounds like you just need to replace the mounts with new OEM ones.
    • AndrewBird
      The Mad Scientist
      • 11898
      ^^^ That's what I was thinking.
      • Charlie
        kid tested, administrator approved
        • 6686
        Am I crazy, or didn't the M42 cars have fluid filled mounts?
        Maybe it's the V8 powered cars.
        -Charlie
        Swing wild, brake later, don't apologize.
        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
        FYYFF
        • Jordan
          • 12912
          M42 and V8's are definately fluid filled.
          The V8's have a BAD habit of popping them when driven like a man.
          https://mtechniqueabs.com/
          • madjurgen
            • May 2005
            • 1203
            Get the IE ones. No extra NVH into the cabin. Good peace of mind.
            As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
            You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
            • nickmp0wer
              • 1427
              speaking of fluid filled mounts, what about filling one with urathane?
              • AdamF 88iS
                • 2051
                6cyl mounts are solid rubber lumps.
                M42 cars and S14 cars have the fluid mounts.
                Put fresh stock mounts in it. If it really makes that much NVH at idle you may have other problems.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
                • MrK
                  • Jan 2006
                  • 709
                  If you call a 304 degree Schrick cam a problem, then you're right.
                  • MrK
                    • Jan 2006
                    • 709
                    Never mind about these... I've already been told by Luke that mounts of this sort would probably buckle real fast with an engine like mine, and I think he's right.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      What kind of fluid fills these things? Is it an oil or something?
                      • RobertK
                        • Jun 2005
                        • 5864
                        If it's a DD stick with rubber mounts.. if not I would go with urethane mounts
                        • AdamF 88iS
                          • 2051
                          Some sort of oil based fluid, almost like a really light grease.
                          Adam Fogg- '88 M3
                          • AdamF 88iS
                            • 2051
                            That would do it, yea.
                            Adam Fogg- '88 M3
