Hi Guys,
After a plethora of topics that came up when using the search function, i was unable to pin point an existing thread that related to my issue (although, several came close).
The breakdown,
a few weeks back, my car was overheating, the fan clutch did not turn on. The aux fan did not turn on either, even when pressing the a/c button. So i jimmy rigged the aux fan to come on manually(worked perfect). That held me over until i ordered an electric fan from Ireland Engineering and a 2-prong temp switch for an E30 318 (80c, pelican part to be exact. wrong switch? see below)
Pelican part purchased: 61-31-1-364-272-82-M323
So Saturday morning i did the following:
-removed fan clutch and fan (tossed it!)
-removed a/c condensor and aux fan
-replaced thermostat with a new 80c
-replaced 3-prong temp switch with 2-prong 82c temp switch. (used high speed wires from original temp switch harness and used spade connectors for new switch)
-installed IE electric fan(cut wires from aux fan, and spliced in new fan with factory a/c harness.)
new coolant, bled the system, etc...
the verdict:
temp gauge sits right in the middle while driving (very little fluctuation below & above middle mark during freeway driving)
when im at a red light or letting the car idle in front of my garage, the needle starts to creep up, and the fan refuses to turn on via the new temp switch.
so, my question(s)
1. incorrect temp switch?
2. does the 3rd wire im no longer using from the temp switch harness need to be spliced in or grounded somewhere? i was under the impression that was the low-speed wire and no longer needed.
3. simple re-bleed all that is needed?
Thanks in advance, and if someone finds this same exact issue on here, please link me for future reference!
The breakdown,
Auxiliary Fan Switch 2-Prong (White Top) 82 Degrees, 318i (1984-85), 325/e/es/i/is/iC (thru 08/87), M3 (thru 02/87), E12 528i/530i, E28 5 Series all, E24 6 Series (09/82-08/86), E23 7 Series all,
Brand: FAE
Brand: FAE
the verdict:
so, my question(s)
