My seiko A/C compressor (6452 1386 464) has three wires coming from it - 2 are red/black and 1 is black -- that have been cut (I believe there should be a connector attached, but it appears to have been cut off and I have three exposed wires). My high pressure switch has one red/black wire that has been cut and is also exposed. I am trying to hook back up the system and can't figure out how the wires attach.
Clearly one of the red/black wires goes to the high pressure switch or are the 2 red/black wires connected together to the high pressure switch? Where does the black wire go (ground/power)?
I appear to be having the same problem as the person in this thread and he has a picture included. See link:
If someone could post some pictures of their wiring for a seiko compressor that would also really help.
FWIW, my a/c system actually works because a PO hacked the compressor wiring to create an on/off direct compressor switch, rather than fix the lower pressure switch. I have now replaced the low pressure switch and am trying to return the system to how it was designed. I have consulted the wiring diagrams to no avail. My car is a 1987 325ic.
Many thanks for your assistance!
Marc
Marc
