Breaking into the trunk and junk yard
  • 96Formula6spd
    • Feb 2013
    • 96
    Hey just I found a e30 and the junk yard today and would like to get into the trunk. Anyways the keys are long gone and the trunk lock has been smashed. Someone had already tried the pry bar method and I added some to that. Did not get anywhere with it so just gave up. May be going back and was wondering if you guys had any tricks to get them open in the junk yard.
    1987 325is- $700 project car
    1996 Pontiac Firebird Formula - Bolt ons,cam, 6 speed of fun.
    2001 Miata - Current DD and to be for sale soon.
    The Build- http://www.r3vlimited.com/board/showthread.php?t=281011
    Parts Car Part Out Left Overs- http://www.r3vlimited.com/board/show...21#post3860521
  • Poorboyz
    • May 2012
    • 2117
    If the lock is smashed try to remove it and push the pin inside...it will open the trunk. I had found an e30 at the junkyard that someone also had tried getting into. The smashed the trunk, lock and just about everything back there. I took a hammer I had and swang the hammer from right to left horizontally hitting the lock and the trunk popped open.
    Sent from my Galaxy Nexus using Tapatalk 4 Beta
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • blueapplesoda
      • Dec 2005
      • 1904
      pop/smash out a tail light and go to work?
      • FLG
        • Sep 2011
        • 3165
        Pop out the rear seat and hit out the ski pass? Then see if you can get to the trunk lock. Just a thought
        Sent from my Galaxy Nexus using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • illest318i
          • 1472
          Light up an M80 where the lock used to be, that should do the trick.
          IG: @_j.wn
          • dnguyen1963
            • Nov 2011
            • 2649
            ^ This. BTW, what is in the trunk that you want to get to?
            • jc72
              • 75
              How would he know if he can't get it open??:roll:
              • nickflic3
                • Sep 2009
                • 3564
                We got kicked out of a junk yard for doing this once lol
                Cammed B25 Swap Daily Driver
                Updated 10/1
                • Quadrajet
                  • Jul 2008
                  • 1278
                  Maybe this car has the "Hooker sticker" in the window! ;)
                  • Ceeker
                    • Sep 2009
                    • 2821
                    BIG flat head screwdriver and sledge hammer. Drive it into the lock as far as you can; wiggle it around and it should pop open. had the same problem here with a parts car I had.
                    jimmy the lock no problem.
                    • nickmcc92
                      • Dec 2012
                      • 442
                      Vise grips and screwdriver to break the inside. Twist it around and push
                      • 96Formula6spd
                        • Feb 2013
                        • 96
                        Alright well I was wanting to check the tail light gaskets as mine are shot. Also looked complete so may be able to raid the tool box in the back for my missing stuff. Plus just to dig around you never know what you will find.
                        • efficient
                          • Feb 2012
                          • 3312
                          lol just buy new tail light gaskets
                          • FLG
                            • Sep 2011
                            • 3165
                            Just buy new taillight gaskets...
                            Beat me to... I know this is r3v but come on. Sometimes I think you guys reuse condoms you're so Damn cheap.
                            • Holland
                              • Nov 2008
                              • 7204
                              This, reusing a taillight gasket is like reusing a timing belt or a condom. They are like 10 dollars dude.
                              Originally posted by DEV0 E30
