Rear Wheel Bearings - What Else?
  • monoblanco
    • Mar 2008
    • 310
    I'm replacing my rear wheel bearings.
    Is there any other part pertaining to the wheel bearings that I should replace?
    After adding the wheel bearings to the shopping cart the web site is
    recommending I purchase the following:
    Axle Shaft Securing Nut, Each
    Snap Ring for Rear Wheel Bearing 79 X 2.5 mm
    Lock Plate for Rear Axle Nut
    Nut, Wheel Bearing/Axle Shaft
    Thanks.
    monoblanco
    www.passportsoccer.com
    You will definitely need new lock plates, should get new nuts, and may need new snap rings.
    • brent5631
      • Jun 2012
      • 421
      Reboot the axles while their free.
      • Chuck C
        • 104
        Looks like the axle nut is on the list twice, but otherwise, yes to everything. Prying that lockring out with a screwdriver is going to send it into the farthest corner of the garage, and you'll never find it, so get new ones.
