Climate Contol Panel Doesn't Light
  • mph
    • Jan 2004
    • 536
    My climate control panel used to light when I first got the car, now none of it does. Anyone know what the problem is?
    Current BMW's:
    2004 330Ci
    1986 European 325i cabrio
    1986 735i
    Previous BMW's:
    1989 325is RIP
    1989 325iX RIP
    2001 740iL RIP
  • Jordan
    • 12911
    dead light bulbs.
    i think there are 2 of them, perhaps 3.
    replace em.
    https://mtechniqueabs.com/
    • mph
      • Jan 2004
      • 536
      Yeha, but the wole climate control used to light (at least I think). Would they all go bad at the same time?
      Where exactly are the lights? Behind what and how does the dash trim come out?
      Current BMW's:
      2004 330Ci
      1986 735i
      Previous BMW's:
      1989 325is RIP
      1989 325iX RIP
      2001 740iL RIP
      • bimmerphile
        • 3495
        There are 3 bulbs. one illum. the temp knob, one for the fan speed knob, and one for the sliders. the sliders have fiber optic inside them to illuminate. Replace the 3 bulbs, and you'll be good.
        • mph
          • Jan 2004
          • 536
          Okay, thanks!
          Current BMW's:
          2004 330Ci
          1986 735i
          Previous BMW's:
          1989 325is RIP
          1989 325iX RIP
          2001 740iL RIP
          • Simon325isport
            • 142
            There's 4 screws to undo two above and behind where your hazard and rear heated window switches are, and the other two you will need a stubby screw driver to get to are located above the accessory tray, all are crosshead screws.
            • LikeCDoos
              • Jan 2004
              • 2522
              FYI: I just did this and it's very easy if all you do is remove the whole plastic peice that contains the radio, obc and climate control. To do this all you do is remove the 2 screws above the hazards, and 2 screws above the little console below the climate control knobs. After you do that pop off the plastic cover over the sliding tabs and remove the 4 more screws. Then take the whole plastic thing out and the 2 bulbs will be right at your reach. Replace them, then put everything back together.
              Here's a diagram of how it is put together, hope that helps:
              • kylebes1
                • May 2004
                • 2804
                I have the same problem!!!
                waht type of bulbs are they? I could find out when I rewmove them, but that would take awhile, and i want to get it all do at the same time.
                • LikeCDoos
                  • Jan 2004
                  • 2522
                  They are 12V 1.2W bulbs and you need 2 of them to light up the whole climate control area.
                  Part Number: 07 50 9 063 579
                  if you have any question feel free to ask me, i just did this.
                  • royalflush313
                    • Mar 2004
                    • 2070
                    excuse me for reviving an old thread.
                    LikeCDoos, where are these two screws located? I was just out trying to figure out how to replace the lights, and I couldnt figure it out, and then found this thread.
                    I didnt see any screws.
                    thanks.
                    It's probably something so easy that im not seeing.
                    ~ Go Canucks Go! ~
                    • LikeCDoos
                      • Jan 2004
                      • 2522
                      There are 2 screws in the top behind your hazards ect (number 12 on the image), and 2 more screws under the panel (number 13 on the image). After you get those disconnect the slider knobs and the small plastic panel behind them to expoze 4 more screws. After you get that off you'll see the 2 bulbs. One bottom left and one top right.
                      • royalflush313
                        • Mar 2004
                        • 2070
                        do the slider knobs just pull off?
                        ~ Go Canucks Go! ~
                        • LikeCDoos
                          • Jan 2004
                          • 2522
                          Yup pull all 3 straight off...then get a small flathead and pop off the plastic cover (#16 in the picture), after that it will expose 2-4 screws (#14 in the picture). After removing a total of 6-8 screws the whole center dash part will come out and you will easily see the 2 small bulbs.
                          • royalflush313
                            • Mar 2004
                            • 2070
                            awesome thanks.
                            I'll go look at it again tomorrow morning.
                            ~ Go Canucks Go! ~
