It appears as if condensation is leaking onto my passenger side carpet and it really sucks. It looks like the leak is happening under the evap valve. Only happens with the AC on. Any ideas? I am getting condensation dripping to the road as normal operation so I don't know why its leaking onto my carpet
AC water leak.
Tags: None
Saw this, may help:
Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future. -
I took a look at the rubber boot and it seemed to be in tact. Here's a video. Im not running the black insulation box that goes around the evaporator/expansion valve. I know it has a little gasket that possibly prevents condensation from falling to the carpet. Could that be it?
Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Yes. That's exactly it. Need to install the cover.I took a look at the rubber boot and it seemed to be in tact. Here's a video. Im not running the black insulation box that goes around the evaporator/expansion valve. I know it has a little gasket that possibly prevents condensation from falling to the carpet. Could that be it?
When in doubt, install it as designed.Comment
