Can you fix a sticky rear defroster switch?
  • optimusp517
    • Oct 2005
    • 797
    It's stuck when I push it in and I have to fuss with it to make it pop back out. When I pull the switch out from the panel I can just push it in and out fine, but once it's put back into the panel it's stuck. There any way to fix it or just have to get a replacement?
  • browntown
    • Jun 2004
    • 3524
    Sounds like the panel is too tight. If you cant get a cheap replacement from the u-pick-it or ebay (10$ or so), and you are careful you might file the opening of the panel a little so it doesnt push in on the sides as much. Just an idea.
    • optimusp517
      • Oct 2005
      • 797
      I'll double check some more about the switch to make sure it's 110% fully functional outsid ethe panel, if that's the case then I'll fine the panels a little down with a filer and see how it reacts. Appreciate the advice :)
      • asubimmer
        • 6482
        dood don't screw w/ a bad defrost switch...they can get stuck on and break you back window if left on for a long time. I would just pick up another switch...a good used one would be fine.
        • lordofthewaters
          • Oct 2005
          • 714
          I agree with ASU. I've heard too many of the broken rear window stories. I'd just replace it.
          Sarcasm is a body's natural defense against stupid.
          When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
          "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
          Old age and treachery will always overcome youth and skill.
          • EtaSport
            • 2853
            Well if the switch sticks on, then snap it out and unplug it. Find something to swap it with and see if it still does it. Mine does sometimes.
            Old and improved:
            • DaN
              • 1265
              The switch isn't timed is it? I don't see how the glass would break because of the switch.
              I've heard of it breaking because of the line repair paint.
              • asubimmer
                • 6482
                they can get stuck on while the car is off...
                • DaN
                  • 1265
                  But the switch only gets power from fuse 8 in the run position. I just looked at the diagram. Can't work with the key off.
                  sorry for the thread jack, lol.
                  • asubimmer
                    • 6482
                    I don't know how but it happens...
                    • Beej '86 325es
                      • 2639
                      Mine turns off when the car is off. My button also gets stuck sometimes. I just punch it with my thumb and it pops back out.
                      -Brandon
                      '86 325es S50
                      '12 VW GTI Autobahn DSG
                      '03 540i M-Sport (sold)
                      '08 Jeep SRT-8 (sold)
                      For sale:
                      S50 TMS chip for Schricks
                      • arsevader
                        • May 2005
                        • 1025
                        Yeah this is true. I always end up leaving mine on when I leave the car. As long as there are no shorts going on you'll be fine (this applies to any switch).
                        • fitz318is
                          • 20
                          Happened to me too, get a new switch, expensive, but so is rear glass.
