Helicoils?
  • MrTom
    • Feb 2006
    • 56
    Helicoils?
    Anyone here used a helicoil to fix a pwnt spark plug hole? Do they work as a long term replacement?
  • Beej '86 325es
    • 2639
    I have no experience actually using them, but guys here at work have, and they say they work great for spark plug holes. I use them in a lot of parts I design, and they are actually stronger than a tapped thread.
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • MrTom
      • Feb 2006
      • 56
      Well i'll let you know how it goes, hehe.
      • Jordan
        • 12912
        Timecert > Helicoil.
        https://mtechniqueabs.com/
        • MrTom
          • Feb 2006
          • 56
          Timecert cost > Helicoil cost
          • bimmer8604
            • 3017
            Timecert- the shit. the shop uses them on EVERYTHING, as they are much better than stock threads in an alum. head.
            Its worth the cost, seriously. helicoils are weak and will eventually strip out again.
            but then again, this is r3v. so, just wrap your sparkplugs in ducttape and that should hold 'em in place long enough.
            kyle
            1988 M3, 97 840, 99 XJ
            DILLIGAF
            • Simon S
              • Oct 2004
              • 3758
              that's what i do.
              -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
              • kansas-ix
                • Jan 2004
                • 1600
                Like BMW's you get what you pay for.
                E30 325ix 62k
                • MrTom
                  • Feb 2006
                  • 56
                  kyle
                  But wouldnt you want to use electical tape? You know, cause of the electricity? :p
                  How much would a timesert cost to have installed if i just took the head somewhere that could do it?
                  • arsevader
                    • May 2005
                    • 1025
                    That maybe true but Time-sert > all
                    threaded inserts threaded, stripped threads, threaded inserts, blown out sparkplugs, stripped threads, stripped out theads, inserts threaded inserts, ford sparkplug repair, threaded insert thread repair spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threaded inserts for stripped threads, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts, striped out threads, threaded inserts, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
                    • bimmer8604
                      • 3017
                      you can leave the head on the car to do timeserts... unless its allready off the car.
                      I think my buddy paid like 200 bucks to have all 6 plug holes done in his s52...
                      kyle
                      DILLIGAF
                      • MrTom
                        • Feb 2006
                        • 56
                        http://www.timesert.com/
                        Ok, i looked around and the only thing i could find was a timesert spark plug repair kit on ebay, for $220 shipped. That's 3 times what i paid for the m42 that needs the plug repaired.
                        I'll stick with helicoils thank you very much.
                        • bimmer8604
                          • 3017
                          goodluck with that.
                          seriously, do the timeserts.
                          kyle
                          DILLIGAF
                          • MrTom
                            • Feb 2006
                            • 56
                            goodluck with that.
                            kyle
                            would i need the 14mm extended or regular timeserts?
                            • bimmer8604
                              • 3017
                              not sure on the m20, but i think they give the measurments u need. your best bet would be to call a shop to see if they've done it before. usually race shops are your best bet, as they have experience doing it. its very easy and expensive to mess up your head, i wouldnt try it myself. i would say the regular should be okay. im not trying to MAKE you do timeserts, but helicoils are weak,and your chance of messing the threads up again are a lot higher. its much better to just rethread them correctly the first time.
                              kyle
                              DILLIGAF
