blinker issue
  • theroundcow
    • 183
    blinker issue
    so when i use my turn stalk to signal right, the instrument cluster shows no lighting for the right signal and clicks really fast. the left works fine. when i use my hazard button, both sides signal just fine. the instrument cluster blinks color under both directions and clicks at the appropriate rate. so i only get this issue when i use the turn stalk, which i did replace when i upgraded to a 13 button obc. when i use my turn stalk theres no blinking inside or outside of the car just a fast clicking.
    is it my turn stalk? help help help
    That is a bad turn signal switch.
    • Poorboyz
      • May 2012
      • 2117
      Could be bad connection at the bulb even though bulb might be blinking...I had this issue and still do at times.
      Sent from my Galaxy Nexus using Tapatalk 2
      Rebuilding since 07/06/2016
      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
      Poorboyz Feedback Thread
      • oliver.r
        • Mar 2012
        • 3839
        blinker fluid reservoir is leaking
        • theroundcow
          • 183
          which bulb connection? in the dash?
          • Poorboyz
            • May 2012
            • 2117
            No, one of your blinker bulbs either in the front or rear of the car. Mine was front passenger.
