ok so the other day i put in the new ICV and Fuel pump relay worked GREAT for a day. the next day on the way to work i was at a stop light and like 15-30 sec in idle the RED CHECK ENGINE LIGHT came on... and the idle reved a little up then down then up and back to normal. Then the light turned green.. and the proceeded to go and the light turned off. and at the next light the same thing happend. The thing is tho it only does it after a few seconds. So then i was going down a hill and i had the clutch ingaged and the shifter in nuetral and while in nuetral the same thing happend once again. So it has to do something with the idle.. Im thinkin maybe a Vacume Hose?
Please help! i Need It asap! Thanks guys
