Fuel line replacement
  • e30Matt
    • 5077
    So my buddy had an encounter with a ditch this morning, damaging the send line from the fuel tank fairly badly. I assume the easiest way to repair it is to cut out the damaged section and replace it with a piece of rubber fuel line w/clamps on either end. Any input? Need info ASAP if this will not work.
    Also, how would I go about doing it? I haven't had enough space to get up under the car and look yet, as there is a 6' puddle of gas underneath it. Is there a way to drop the hard fuel lines from the location right where the frame rails turn upward by the firewall?
  • DaN
    • 1265
    You could patch it with rubber line. Make sure its for fuel injection (higher pressure).
    Unless you have something to flare the smooth ends of a cut metal line, then run rubber for the whole length, so you have a nipple on each end,for the hose to grab onto. Tie it up out of the way.
    Replace it with metal line later.
