driving along normal at 35 with a cop following me after he saw do a pull and the car starts stumbling then shuts off. Each time it stumbled the check engine light flickered but didnt stay on. Then it died.. But starts right up again. The cop probably felt sorry for me and didnt stop and i was able to get it home. It will start and idle for a while then just shut off. Each time it restarts like normal. Im thinking crank sensor or something???
OBD1 M52 turbo cutting out
I threw a new CPS in it.. No change. I checked the harness out best I could without removing it for a short. Its weird as it runs great and then just dies. It will restart and run for varying lengths of time. I hate problems like this I wish it would just die and not run at all Then i could test things
Originally posted by LJ851 View PostCheck fuel pressure ? You could rig a gauge to watch what happens when it fails.
Originally posted by blunttech View PostWell yes. Its only dont it when warm. I gotta get over to superdupers to borrow his peake tool and pull the codes. I really need to get one . Thanks guys
I know you already threw a new CPS at it, but I'd test it anyway... I have gotten bad CPS/TPS's before new in the box.
Originally posted by jalopi View PostYeah... something electrical's probably bad then, I'd rule out fuel. Typically, when electrical components (wires, sensors, motors, ect) are starting to get bad they'll start acting up once they get hot. Based on your symptoms, it sounds like something related to how the computer watches timing is acting up.
