Thermostat installed upside down
  • jackyl
    • Sep 2005
    • 76
    Hi there.
    I´ve opened the spot where´s the thermostat and noticed that the arrow on him, was pointing down instead of up .
    I think the correct position is the arrow pointing up.
    What´s the problem of pointing down instead of up?
    (i´ve corrected the position).
    Have it done bad to the coolling system?
    It didn´t worked in the same way?
    (everywhere i read there´s only saying, put with the arrow up, but why??? i don´t know)
    Thanks.
    Sorry for my ignorance.
  • DaN
    • 1265
    I think it has to be up because of the little hole at the top.
    I'm guessing for easy bleeding.
    • AdamF 88iS
      • 2051
      It will be fine.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • Nick325is
        • 1409
        The last thermostat I had did not have an arrow and when I installed it coolant leaked all out of the thermostat housing. I replaced it with a thermostat with the arrow lined up and no problems.
        nick
