innovative mtx-l install help
  • dshiznitbmwe30
    • 83
    So i have been doing a lot of reading and i keep getting mixed info. one person will say just remove your stock narrow band and run the brown wire from your wide-band to the black wire off of your o2 sensor connector. Then another post says to keep your narrow band and just weld the included bung onto the exhaust and run the wide-band separately. I have read the the innovative wide-band can emulate the narrow band readings back to the ecu. Can someone give me a little more insight on this. I would prefer to just use the stock o2 bung.
    Thanks in advance
