Power window/Mirrors aint workin
    Okay, so if any of you are looking at OTHER threads besides the Gay ass jordan threads, please be so kind to read this:
    In the new car i just got, the mirrors and windows arent working.
    I have power to the fuse block/relays. Power to the switches/circuit breakers, and a good ground on everything. Wires look good in the door jam, and I am pretty sure i have power to the motors and stuff. Unless i have a bad ground on all the motors at the same time, then i dunno whats up.
    Ofcourse fuses are good, switches work, good grounds, power to everything, i have continuity on all the wires i'm supposed to have. The only thing I didnt do was pull the door panels off and check. What are the odds of all the motors being burnt out? I guess my next deal will be to pull the door panels off, and check the grounds in the doors? I cant think of any other thing that would cause the circuit to not get completed...
    Sorry for hte long post, but i had to fill in all the info so people didnt respond with "OMG Check fuses". I think higher than most people sometimes.
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
    dgbdf
    i had a similar prob. when i rebuilt my beater. it had power to all switches etc., but it ended up being hte connection at the starter.
    check that out.
      why would it be the connection at the starter? tht makes no since, as i doubt any of those wires for the power windows go to the starter... hrm, i dunno.
      kyle
      DILLIGAF
        If you read the 2nd post in this thread: http://www.r3vlimited.com/board/showthread.php?t=64071
        It mentions something about an unloader relay no allowing the power windows to work or something along those lines so appearently the starter has something to do with the power windows.
          sah-wheet. yea, i just relized that the windows dont work when u crank the car.
          so maybe this is it.
          kyle
          DILLIGAF
