Oil level sender resistance measurement?
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Can someone please measure the resistance of the oil level dynamic pins 1 and 2 from the sensor itself? I am not using this sensor anymore for my s62 and want to simulate a"full" as to remove the active check control light.
    The static is easy, just ground the wire. The dynamic is harder because it needs some sort of resistance to ground.
    Thanks so much guys for the help.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
  • Swanny
    • Mar 2012
    • 2834
    I'm stripping down my b25 block today so I can send you some measurements.
    Swanny!
    SUCKERS.
    • Garageaholic
      • Dec 2005
      • 5204
      Thanks Sean!!
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      • SpecM
        • Oct 2005
        • 4531
        info stolen from e30tech:
        Ground pin 2 in C101
        Ground pin 10 in C101 through a 1000 Ohm resistor.
        1989 cirrisblau-metallic 325i
        • Garageaholic
          • Dec 2005
          • 5204
          Hmm 1K...I'll try that tonight. Thanks!
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          • Swanny
            • Mar 2012
            • 2834
            It has this many...
            Swanny!
            SUCKERS.
            • Garageaholic
              • Dec 2005
              • 5204
              Perfect. You're both telling the same story. Thanks guys.
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
