Good evening,
I just picked up another e30 a few weeks ago and am having a problem with the electric fan staying on. If I turn the ac on the fan stays running when I shut the car off. The fan stops with the engine off if I remove k1 relay but stays on if I remove k6. I replaced k1 but it still happens. I checked fuse 20 and it has 0 volts with the key off. Do you think I'm lucky enough to have two bad relays? Has anyone had a similar problem? If I pull out k1 the fan stops and doesn't start when I put it back in. The fan doesn't start if i jump the switches with the key off. Any ideas would be greatly appreciated. Thank you.
Rob
Rob
