Help! Car won't keep idle
  • KIRIEIW
    • Dec 2012
    • 3385
    Posting for a friend. Basically the problem is comparable to a bad carburetor (though bmw's don't have them). You can't keep the car idle with out gassing it, when you hold the gas with a steady foot the rpms will slowley drop, and if you let it idle the car will just die. Gassing it too much at idle will choke out the car so you need to pump the gas peddle too get those rpms up and once there up hold you foot down, but like I said earlier the rpms will slowley drop. Any ideas? Vacuume leak, maybe fuel pump? Was running fine until one day he was stuck stranded on the road.
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
  • efficient
    • Feb 2012
    • 3312
    cps
    • FLG
      • Sep 2011
      • 3165
      Have a smoke test done first and go from there.
      Sent from my SCH-I545 using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • KIRIEIW
        • Dec 2012
        • 3385
        Originally posted by efficient
        cps
        But there's spark and you can get it started once you pump the peddle 4-5 times.
        1991
        • KIRIEIW
          • Dec 2012
          • 3385
          What's a smoke test? We did a compression test yesterday and everything checked out fine.
          1991
          • jalopi
            • 2370
            Check fuel. Also, a smoke test is when you pressurize the intake or evap or whatever system with smoke from a smoke machine. Basically, if you've got any leaks, you'll see smoke to start coming out.
            • 3ionCa
              • Feb 2014
              • 314
              Ey I should actually try this, it could help me find why Im not passing smog
