so my anti lock light comes on, and the abs doesnt work. i pluged an autologic scanner to it (same scanner the dealer uses) and it could not comunicate with the abs system. anyways here is the symptoms: when you start the car the abs light is off, the first time you apply the brakes to stop the abs engages and then the light comes on, after that the brakes work fine, except the abs, but the light stays on untill i shut the car off.......and then it starts all over.
anybody ever have this problem? what did they find, any help would be great thanks.
