Ever since I installed higher compression pistons, I've been having some trouble with my brake pressure. Unless I rev the engine to about 2 or 3k, my pedal is stiff and unresponsive. It's as if I need to rev the engine to allow the MC to collect enough vaccuum to work properly.
The result is that at low engine speeds, I only have a limited ability to brake, and while this isn't outright dangerous (since at low rpms I'm probably not going very fast), I'd like to know the root of the problem and restore normal brake pressure.
Any ideas?
Any ideas?
