Odometer stopped working randomly
  • ipunchfish
    • Oct 2009
    • 106
    I had replaced the gears a couple weeks ago and dropped my car off to get painted. I finally pick it up and the odometer is now dead. I have no idea what could have happened.
  • ipunchfish
    • Oct 2009
    • 106
    Which fuse controls the odometer motor? I have't seen anything else wrong with the instrument cluster.
    • Semblance
      • Jan 2011
      • 433
      Did you use garagistic gears? Are you sure the spacer was installed right? IIRC the gears can shift out of contact if not. Have you opened it up to make sure the gears are still in sync?
      '89 lachssilber vert - Frau Blücher
      '84 alpine 2dr - gone to the great beyond...
      '00 titanium 4dr e46 - bricked
      • Exodus_2pt0
        • 5943
        Is your trip odo at 0?
        No E30 Club
        • ipunchfish
          • Oct 2009
          • 106
          No. Its at the trip before I took it in.
          • Tom.
            • Sep 2012
            • 121
            you may have over tightened the plastic gear cover, or put the tiny little o-ring (the one that holds he gears down) on too tight.
            • ipunchfish
              • Oct 2009
              • 106
              Its working intermittently. I'm going to observe it over the next couple days to see WTF is going on.
