Brake Switch Bracket
  • SkorcherX
    • Jun 2011
    • 267
    I broke the little plastic insert that holds the plastic brake switch to the metal bracket. I have attempted to zip tie it up in there, but alas my brake lights are forever on.
    I have searched RealOEM.com and Pelican in an attempt to find a replacement bracket so I can properly re-install my brake switch.
    Does anyone know where i can buy one or have one around I can buy from you?
    Thanks.
  • SkorcherX
    • Jun 2011
    • 267
    Looking at it... I think the plastic housing on the switch may actually be broken. The switch still functions, however can not longer be positioned in a manner for it to work as intended.
    Manually depressing the plunger will turn the lights off... I ordered a new switch... we will see if I just through $14 down the drain or not.
      The new switch will be the fix.
