'84 325e - all original drive train and electronics
Yesterday afternoon, I tried to start the car, cranks fine but was not getting spark or fuel. When turning key, the main relay would not click. Then after 3 tries it clicked and the car fired right up. Drove it another 30 miles that day with no issues. Went to O'Reilly's last night to pick up wiper blades and Rotella T. When I came out, same issue. Except this time the main relay does click, but still not fuel or spark. I have no power at the coil. Fuel pumps do not function while I'm cranking the car. I jumped the fuel pump relay and the pumps kick on. I also swapped around the relays and put in a brand new main relay, still no fire or fuel.
All relay connections were clean, wires running to relays look good. ICV is new (wouldn't suspect that anyway). Timing belt has less than 5k on it. I'm going to go back later this morning with a meter to check ohms on the reference and speed sensors on the flywheel. The only other issue the car has had is it runs a bit rich, but I've traced that to a burned section of O2 sensor cable. But even that shouldn't cause no spark/no fuel.
My buddies '85 e28 had this same problem, turned out to be the security module had shorted and was cutting fuel and spark. He bypassed it and that fixed it. Does the early Eta have one of these? I saw a similar small black box under the headlight switch area with two similar green plugs running to it. Anyone familiar with this? Of course I left without writing down the part number off that black box.
