Friends,
Grateful to be learning a lot through this community. I have a 89 325i Sedan, and it has a few electrical gremlins. Hopefully someone can point me in the right direction.
1) Rear Passenger Window only works with the switch on the center console. The switch on the door doesn't open/close it. I've tried changing the switch with a known good one, that didn't help.
2) Rear DS window doesn't work at all. Where would you start with the troubleshooting on this?
3) A couple of times, the lights went crazy. Check lights turned on, but then they started working again. A couple of times, when I would turn on the right turn signal and then brake, the flasher sped up like a bulb was out.
4) PS Rear view mirror doesn't move. I can hear it trying to move, but it won't. DS moves fine.
New to BMWs but not to cars, but electrical stuff scares me so if y'all could school me some, that would be great!
