e30 radiator questions
  • McDewbie
    • Apr 2013
    • 10
    what is the difference between an e36 and e30 radiator? i just snapped the upper hose neck off of mine and would like to put in an aluminum rad. now i cant find one for a non m e30 but i can for an e36, they llook the same and bimmerworld lists a upgraded rad for both applications with same part number. wondering if i buy an e36 aluminum rad will it fit without any hassle? or should i put in a craptastic plastic oem BMW part?
    thanks, Evan
  • illest318i
    • 1472
    It'll work, I have an e36 radiator in mine. The only thing is I don't have mounts so I use zip ties.
    IG: @_j.wn
    • McDewbie
      • Apr 2013
      • 10
      But I won't have to make a bunch of custom hoses? And all the señora will plug right in and work?
      • jalopi
        • 2370
        It depends - if you've got an early e30 (pre '88 ) then the rads are different... the hoses attach to the opposite ends of the rad. However, if you've got an 88 or newer I think it's pretty much a direct fit. A few things need to be tweaked but this rad swap has been heavily covered.
        Also, pro tip:
        Amazon & ebay have e36 mishimoto rads for about $220-250 - these suckers have a lifetime warranty. Definitely worth the extra cash.
        • illest318i
          • 1472
          No, no custom hoses. Everything is lined up for the hoses. I have a late 25i so if you have an early or a 318i then I'm not sure.
          IG: @_j.wn
            • 37829
            The E36 6 cylinder radiator is a direct fit to a late model E30. No zip ties needed.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
