there is a single green wire that runs to the motec back to a white connector that plugs into something? what is the single green wire and that plugs into that white connector? wires that also plug into that connector go to the ignition connector
wiring help.
No i have the harness out of the car because i am removing everything i dont need. When i removed it my policy was label what you need and cut everything else out that you didnt label. Well i had a fire in the car and that whole clusters labels got burned off, if it had labels i dont remember. But ill take pics tomorrow. The wire is green with black stripe and goes from the motronic back to a bosch 30amp relay. It is tied to another grean amd black wire that goes off to this white connecter that plugs into god knows what and from there it branches off to a bunch of other wires. One of which goes up to the ignition cylinder. On the ignition cylinder there is only two plugs. One is a bunch of wires togethet and one is that single wire that attaches to the bottom of the cylinder plugset.
