Temp gauge at 3/4 but IR reading is 180...
  • dude8383
    • Jan 2005
    • 10387
    So I'm almost done building my vert and I have a peculiar problem.
    The car warms up to the 3/4 mark and the gauge stays pegged there... I have heat, IR scanner shows 180 degrees at the housing.
    Where should I start? Potential problem with the wiring? I checked the ground nut on the cluster already but it was nice and tight...
    Trying to bring this car home but want to iron everything out... would appreciate your help!
  • dude8383
    • Jan 2005
    • 10387
    Bump
    • SmokeE30
      • 1730
      How are your si board batteries? If they are bad them can effect fuel and temp gauges
      Shawn @ Bimmerbuddies
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      bimmerbuddiesllc@gmail.com
      • AndrewBird
        The Mad Scientist
        • 11897
        Could be as simple as a bad sender. Bentley might have a way of testing it.
        • dude8383
          • Jan 2005
          • 10387
          Good points guys. Anyway to know if the SI boards are bad?
          The car only has 104k on the clock but the motor has about 136k. I gotta check that I've bled it properly as well. I drove the car around today and noticed that the heater core hoses don't get hot... Maybe I have them switched around?
          Right now I have it hooked as follows:
          Hose from rear of the block - lower pipe on heater core
          Hose from the front - upper pipe
          Is that correct? I haven't been able to find a decent pic of that area.
          Nitro, I'll check the Bentley tomorrow for testing info.
          Thanks guys.
          • jclar
            • 265
            Not sure what your issue is but the configuration of your heater core hoses are correct.
            '86 325es M50
            • FLG
              • Sep 2011
              • 3165
              Yes, heater hose from head goes lower, from thermostat goes to upper.
              Try a new sender, or check the bently for how to test the current sender. Im sure a quick resistance test when the car is hot will tell you the answer. Do you have heat when you rev the engine or are driving? Might just need to be bled.
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
