Hey Guys,
Backstory: This weekend I took my 87 325is out to an autox (its first autox, new owner :) ) and noticed that by my third run, WOT >5k rpm was causing the car to lose power. The motor wasn't stalling, but it would sit at 5k during WOT and slowly decrease RPM if held for more than 10 seconds. In the lower ranges, however, the car idled and felt normal.
Since then, I did some research and went out to test the fuel pressure coming into the fuel rail. The gauge I bought from Autozone was pretty shit and not accurate (it read ~1.5psi when teed pre and post FPR when I definitely had pressure), so I jumped the fuel pump relay for 30 seconds following this test: http://forums.bimmerforums.com/forum...-fuel-pressure (sixth post, Aleman). I only got 400 ml to spit out, with an inconsistent flowrate, so I assumed that it was one of my pumps.
So here's the thing, I've replaced both the inline and in tank fuel pumps and filter for this car right when I bought it 2 months ago. I can't imagine one of them has failed. I have however noticed that the inline pump has been noisy, and also changes pitch after the car is warmed up.
I have a couple questions:
Is it possible that my newly replaced inline pump has gone bad? Does the whine imply malfunctioning?
I haven't even considered the FPR - as the fuel pump test I performed wasn't cranking the engine, so the vacuum line wouldn't have been activating the regulator. In the case that the FPR was the culprit, could it have caused the low volume of fuel even though the engine wasn't cranking?
Edit: I just pulled the inline filter and bench tested it, it was pushing out fluid nicely. Also there are no leaks in the system that I can tell or smell.
Thanks for the help guys!
-David
-David
