SLOVED!!! ANY Ideas?? Spark / Ignition Cutting out
No, not that I know of. Signal. Should just go thru the harness into the dme. Can you replicate the symptoms exactly with different cps 's?
Sent from my SCH-I545 using Tapatalk 2
That's what I thought too. I have too CPSs. One plastic one metal, both ohm out in spec. Also have tried multiple dmes, the problem exists in every situation or combination of those switched around. So it would have to be something I'm not changing.... Or it's time to buy a third new metal CPS. Hahaha!
What does that fact that it can idle fine once started and settled out tell us? Anything? Or even when driving. Like, I just know In between gear Changes it will have to hiccup for a second then I go on my way...
Did you check the air gap on the cps to the wheel is 1mm?
I know when i had this issue someone through out the idea that the OBC code relay control could be causing the issue. Didnt turn out to be, but was reasonable.
Also, did you make sure the harmonic wasnt bent or something and wobbling?
I did check the gap. That was good for sure. Maybe I will take the harmonic off an inspect it real close and pay attention while putting it back on.
I saw in your thread, someone mentioned front main bearing could be bad.... Hope this isn't the case... I mean my engine has always seemed healthy.. But it's still old I guess.
I am still having the exact same intermitant issue, MIL and ignition cut-out and tach drop when the throttle is released or when returning to idle
my car will go for a couple days and not act up... and then it will do it several times in one trip!
seems to act up more so when its a bit warmer
I have replaced DME (tried three, used), CPS (new from BMW), engine harness (used), all ignition parts (all new OE stuff), fix a couple little vac leaks
I'm in the process of taking my front end apart and replacing with a real oem metal CPS. I've replaced multiple computers. I know that isn't it. I even tried the 90's 525 ECU. Engine ran normal but still cut out under load.
I'll keep this updated as my process thankfully it's a summer car.
