Idle Problem
  • BeaterE30
    • Oct 2013
    • 35
    Idle Problem
    Hey guys,
    I'm pretty new to r3v, but my brother alkasquawlik used to post a lot around here. I inherited his e30 and there seems to be an idle problem. Whenever the car is at a stop, the car stalls out. When I'm moving there doesnt seem to be any issue. My guess is that the idle control valve may need to be adjusted or something. I'm a novice when it comes to this kind of shit, so any advice would be appreciated.
    Thanks
    1985 528e
    1991 325ix
    1992 318i Convertible
    "this question is kind of like asking: would you rather be ass raped by a gorrilla with lube on his dick or butt pounded by a prison inmate with size 14 shoes and no lube....?"
  • Danny915
    • Sep 2012
    • 200
    take the idle control valve out and give it a good cleaning with some brake cleanerthere might be an adjustment screw on it that you could mess with to see if it improves idle. Disconnect and reconnect the battery as well, clean all grounds, etc... After all this the idle may be rough for a few minutes, its the ICV relearning idle.
    • BeaterE30
      • Oct 2013
      • 35
      ok so i cleaned the ICV. That didn't seem to do anything. now that you mention it, I did disconnect my battery while installing my sub. That is when the problems started happening. Do you think it could just be a bad connection on the battery?
      1985 528e
      1991 325ix
      • Danny915
        • Sep 2012
        • 200
        It's a possibility,tighten the connection and try just driving it for 30 min, icv might just need to relearn and reset itself
        • BeaterE30
          • Oct 2013
          • 35
          I just cleaned the terminals of the battery. It still has the problem.
          1985 528e
          1991 325ix
          • Danny915
            • Sep 2012
            • 200
            will it idle on its on at all?
            • BeaterE30
              • Oct 2013
              • 35
              Nice. I just drove it around for about 10-15 minutes and the idle seems to be working. I think the ICV did just need to reset itself. Hopefully the more I drive it the better it gets. Thanks Danny915
              1985 528e
              1991 325ix
              • Danny915
                • Sep 2012
                • 200
                no problem
                • Jed the Fred
                  • Feb 2013
                  • 51
                  Check your vacuum seal
                  1991 Convertible (The BathTub)
