This seems painfully obvious, but when the key is in the run position is there any power at the fuel pump? And if so, is the pump running?
NEED HELP FAST - obc issue
yeah Well Dang O dang,
I fuggin fried AND lost.....I don tknow what 2 say ...Scootty WE tried. Me & Matt wan ted 2 c dat ting start more den u. Wes tried.
ding ding riend 2 in da morning?sigpic
Wastedincome420@yahoo.com
CURRENT STOCK LIST:
00' e38 750iL HighLine=Highway Queen
92' e30 318 vert=Aint going anywhere
91' e34 535iM=Aint going anywhere
91' e34 525iA=For parts
92' e34 535iA=For parts
Originally posted by MarkHThis seems painfully obvious, but when the key is in the run position is there any power at the fuel pump? And if so, is the pump running?
KeyON power IS 2 the relaysigpic
CURRENT STOCK LIST:
I haven't heard a fucking thing happening at the fuel pump.Originally posted by MarkHThis seems painfully obvious, but when the key is in the run position is there any power at the fuel pump? And if so, is the pump running?
wtf does that say Mark? I don't understand hippie.Originally posted by wastedincomeyeah Well Dang O dang,
We'll crack at it again tomorrow. Fun times.Comment
Originally posted by BimmerfanatikI haven't heard a fucking thing happening at the fuel pump.
Welll Scott I'll leave you 2 figgure dat out. LMAO...Cuz I aint gots a fuckin clue now..times 4 bedsigpic
CURRENT STOCK LIST:
damn I wish we hads internet @ da shop.....sigpic
CURRENT STOCK LIST:
werd. this back and forth thing sucks.Originally posted by wastedincomedamn I wish we hads internet @ da shop.....Comment
Originally posted by Bimmerfanatikwerd. this back and forth thing sucks.
Yup Well like ANY "well oiled machine" i needs 2 rest and sleep I will pick this back up in da mornin////werd 2 ya muthasigpic
CURRENT STOCK LIST:
nice. call me when you're up killa.Originally posted by wastedincomeYup Well like ANY "well oiled machine" i needs 2 rest and sleep I will pick this back up in da mornin////werd 2 ya muthaComment
Check for spark. If you DO have spark, then the OBC is not the problem. The OBC cuts fuel AND DME fuctions, so no spark.
If you have no spark and no fuel at the same time, it's pretty much OBC, crank sensors, main relay, or DME.
If you do have spark, its fuel pump or fuel pump relay.
Does the car have an aftermarket alarm?
EDIT: the car is an 87, so the main fuel pump is not under the back seat, it's under the car, just ahead of the left rear wheel.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
As always fast and helpful Adam.Originally posted by AdamF 88iSCheck for spark. If you DO have spark, then the OBC is not the problem. The OBC cuts fuel AND DME fuctions, so no spark.
As the car was cranking, I pulled the wire off the ignition coil and held it close to the coil, but not on. I had spark.
The ONLY thing that was done differently was the removal of the OBC harness, and the frying of that silly green plug that plugs into the OBC relay box.
I checked the fuel pump relay, even swapped it with a known good one. Still de nada. What are the odds of the fuel pump just up and dying on me with the above circumstances present?
No aftermarket alarm present.
Assuming there's no voltage at the fuel pump...what next?
I seriously HATE chasing down stuff like this. Why, oh why did I mess with it?Comment
hey, I have a large OBC box here if you want to borrow it... lemme know... can mail today until 11:30 or so.
Pop off one of the fuel lines and crank for a second to see if you have fuel pressure. If you have no pressure but do have voltage at the pump then you'll have to get a pump for it.Adam Fogg- '88 M3
