High Idle after new fuel filter!
  • nunezfrancisco30
    • Mar 2013
    • 94
    Has anyone ever encountered this before? I replaced my fuel filter yesterday as part of maintenance. When I started my car up it idled high! 1500-1600! The only time that it idles at 1k is when I first start the car, a couple of seconds after it starts increasing rpm until it reaches the 1500-1600. any insight on what to do will be greatly appreciated! thanks
  • LagunaSecaBlue
    • Sep 2013
    • 360
    Try adjusting your Throttle Cable.
    #AZE30
    1991 318i
    1989 325i
    1989 335i
    • nunezfrancisco30
      • Mar 2013
      • 94
      How would you adjust the throttle cable? It has some slack at idle, which means the throttle plate is closed properly while at idle.right?
      • jalopi
        • 2370
        It's probably just coincidence that the idle went high after the fuel filter change. Make sure your ICV is working right.
