Uneven front wheel poke
in the photo it looks pretty much the same to me.
What are the alignment values? do you have the same bushings for the control arms? are the control arms true?'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
Yeah I realized the pic is useless after posting lol. But it drives straight, but alignment isn't perfect. the poke on the drivers side is about 3-5mm more than the left.Comment
No. Caster is kind of like a reclining seat. Except the seat is a strut. No matter how far forwards or backwards you take the seat, nothing changes side-to-side... not sure if that's a good analogy or not.
Could be a difference in camber... maybe? Although you'd probably be able to tell.
One thing to note - what are your wheels, and where did you get them from? I'm really reaching here, but what are the chances you've got two different offsets?Comment
I have camber plates both at -3 degrees. My wheels are HRE 505s.... I doubt that's it. Maybe it just needs an alignment I guess I'll get that done and go from thereNo. Caster is kind of like a reclining seat. Except the seat is a strut. No matter how far forwards or backwards you take the seat, nothing changes side-to-side... not sure if that's a good analogy or not.
Setting the camber plates based on the marks on them is not the correct way to go about it. You need an alignment done by a professional.Comment
Try removing the stance works sticker, if that does not help...set the car on fire.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8isComment
lol... it's probably remarkably close for a visual alignment, but yes, you should probably go get it checked at a shop. Did you ever get it aligned after slamming and camber-ing your car? If not, I'm amazed that you still have front tires.Comment
The car was hit and never fixed properly. I've seen it many times.'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
