I bought a turbo kit from another member on here, and when I was installing the feed line I was tightening down the adapter that fits in place in the oil pressure sensor location. Apparently the thread wasn't right, as after tightening it loosened up instantly. Going in it seemed to be fine, but right when it started getting snug it gave out.
It's pretty obvious the threads are stripped. I figured if I could JB weld the thread and base it would seal fine, and I didn't care since I would never be taking it out. But that didn't work, the car is running now but it has a small drip from the adapter. I can deal with the drip as it is very small but I would like to get it fixed.
My question is what are my options now? I did notice that the thread goes very deep into the block, could I get a longer threaded pipe with the correct threading and just run it deeper into the block? Or did I screw myself over?
I can easily get the JB weld out, it seems like it didn't even harden at all so that's not an issue.
Thanks.
Thanks.
