E30 L-Jetronic to Motronic Conversion
  • smokenbaby
    • Jan 2006
    • 9
    Other than the gearbox (260 - with engine speed and TDC sensors) what else needs to be changed. I am putting a 2.5 into my E30 pre F/L 320. First and biggest problem is finding a gearbox that has the sensor ports in the bellhousing. What else do I need to change ie. complete wiring loom or can I just change the engine loom. From what I can see there is no real need to change the whole lot. The only unknowns that I can find is the fuel pump relay and main relay. The other is the rev counter. The computer picks up the engine speed via the bellhousing mounted sensor but how does it get the info to the rev counter. Obviously the computer will have a wire leading to the dash but is it a plug and play conversion (will the pre F/L dash and wiring match the Motronic computer loom).
    only the dead see the end of war
  • e30Matt
    • 5077
    Methinks you should just pluck the whole lot from a donor car to save yourself a ton of heartbreak.
    • smokenbaby
      • Jan 2006
      • 9
      I do have the complete car as a donor. Thing is I am sure I can get away without changing the under dash wiring, front to rear wiring and light, charge ect wiring. Should be able to just use the engine loom and be done with it.
      Thanks for the reply though.
      • Mot
        45 toting redneck
        • 4018
        Im intrested too, I have a 2.7L hybrid running off crappy L Jetronic 1.0, Id atleast like to see whats involved, most likely im going piggy back tho.
        • BlueJ85
          • Nov 2008
          • 120
          Back from the dead--is there a how-to on this somewheres??? I'll keep searching but this was the most likely match I found...
          (1985 Arktisblau Metallic Euro 323i)--Track car
