Car misfiring after it rains
  • HarryPotter
    • Jan 2010
    • 3642
    After a good rain or a on and off rainy day before my car drives for a bit it will misfire pretty bad in lower rpm's. Not exactly sure what would be causing it throwing in the rain issue. If it's dry out and everything cars fine but again with the rain it's really annoying, just not sure where I would start looking. Figure water is getting in something either electrical or who knows.
    Any ideas?
    John F. Kennedy
  • mtech325
    • May 2008
    • 559
    Came across this thread, seems like hood seals, crank sensor, or possibly ignition wires, or the wiring harness itself:
    • Vtec?lol
      • Dec 2009
      • 3278
      you're getting water on or in your distributor (m20)
      you're getting water in you spark plug valley (m42)
      • Holland
        • Nov 2008
        • 7176
        Plug wire or coil wire not seating properly?
        Originally posted by DEV0 E30
        • jalopi
          • 2370
          Get a spray bottle that sprays real fine. Then, on a dry day, when it's not misfiring, mildly spray around the ignition system. It'll start misfiring when you hit whatever's bad.
          • HarryPotter
            • Jan 2010
            • 3642
            Thanks guys that's what I was thinking, I fucked up my radiator shroud that covers the radiator and the fan so I'm thinking waters getting into the dizzy. I'll check it out thanks for the responses.
            John F. Kennedy
              Aged ignition wires can cause this. If over 10 years old replaced all of the ignition system from the coil to the head.
              • CW325
                • Jul 2011
                • 1434
                I have a similar problem and replaced my distributer and rotor but it didn't help. I think I'll try ignition wires next and see what happens.
                • george graves
                  • 19992
                  I had the same problem. I replaced the ignition wires and it fixed it.
                  Apparently this is a common thing. Some old guy that I was talking to at a repair shop said, that after the first rain, they always get cars coming in complaining of a mis-fire.
                  Originally posted by Matt-B
                  • jrockbk
                    • Jun 2013
                    • 369
                    Do this!
                    • Roblang
                      • Dec 2013
                      • 4
                      Distributor cap,rotor,wires, or coil. Seems as if water is getting into ignition system to me..bad plugs too
