Cold+clutch=dead pedal/slave?
  • Track89
    • 153
    I've dont a bit of searching but couldn't track down a straight answer.
    -It was about 20-30degress,
    -I went to take off for work and the clutch lost pressure and leaked some fluid underneath.
    -clutch has to be pulled up by hand, will not let me in gear
    I was told either the clutch space and/or master cyl. Does anyone know exactly which it would be?
    -mike
    BMWfanaticVR6addict
    8 e30s - 1 e36 m3 - 3 corrado vr6s - 1 mk2 vr6 - 1 735il - 1 525i - 1 miata
    (the following have been sold, crashed, stolen or parted)
  • jalopi
    • 2370
    The cold is most likely a coincidence...
    Also, if you're going to replace your clutch hydraulics, do them both. Odds are that the other is on its way out too. No way of telling which one is bad unless you can actually see which one is leaking... and make sure it's not the rubber line leaking either.
    Just checked rockauto... for less than $35 shipped you can get both the master and slave. I'd order them both.
    • Track89
      • 153
      Will get it jacked up t/n and check it out. what is the rubber line, a PITA im assuming?
      Sounds like the plan @ 35$ shipped
      BMWfanaticVR6addict
      • jalopi
        • 2370
        no it's not that bad. There's a hard line coming off the master cylinder (in the engine bay) that runs to a rubber line... it's pretty much a brake hose. Pretty easy to get to and replace.
        • Chessmaster
          • Jun 2012
          • 501
          Also make sure your master cylimder bracket didnt crack, mine cracked a few days ago and led me on a chase try to figue out my "clutch issue".
          • Track89
            • 153
            Noted.
            Do the clutch/brakes share the same fluid resi?
            BMWfanaticVR6addict
            • jalopi
              • 2370
              Yeah, they do.
              • Track89
                • 153
                So far I replaced the slave and have no fluid coming out of the bleeder, clutch is still limp.
                The master is also shot I'm guessing, any werds of wisdom?
                BMWfanaticVR6addict
                • Track89
                  • 153
                  Edit: I Just reinstalled the slave and got fluid out of the bleeder! I'm letting it gravity bleed now.
                  BMWfanaticVR6addict
                  • jalopi
                    • 2370
                    Cool. Did it end up fixing your issue?
                    • Track89
                      • 153
                      Yessir. Idk how much I trust the gravity bleed but it feels smooth for now.. Ill just leave it be. Thanx again
                      BMWfanaticVR6addict
                      • jalopi
                        • 2370
                        Gravity bleeding works just fine. Sometimes you need someone to put some pressure on it to squeeze a dingleberry of air out, but most of the time (and for most setups) the gravity method will get the job done.
                        • Track89
                          • 153
                          Where is this pressure you speak of applied? To the pedal, line from resi?
                          BMWfanaticVR6addict
                          • Track89
                            • 153
                            Update: car is drivable but the clutch feels more on/off than it did before. It felt like there was a catch "area" and now it feels like a catch "point".. If that makes sense
                            BMWfanaticVR6addict
