e30 regulators
  • e30sky
    • Aug 2013
    • 106
    e30 regulators
    hey guys i have a 85 318i sedan, ummmm the windows are all power windows but its a bit too expensive to buy them brand new. is it possible for me to buy the manual set up and just remove the electronic one and replace it with manual instead? plus its less problem too lol
  • SmokeE30
    • 1730
    buy used regulators in power or manual. theres an 84 318 being parted out that was posted today in the parts fs section that probably has what you need for cheap
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
    • kingston
      • Jun 2010
      • 2669
      Yes, you can do that. Be aware that early model window regulators are different that late models, and coupe fronts are different that sedan fronts.
      Good luck!
      Originally posted by LJ851
      kingston is the play by play announcer for this thread.
      ‘Tis by the grace of God that my cars run!
      Originally posted by unloadedak
      #teamross
      Siobhan's Build Thread - UPDATED!
      • e30sky
        • Aug 2013
        • 106
        thanks alot
        hey man thanks alot........i will check it out. you wouldn't happen to know the name of the user?
        • e30sky
          • Aug 2013
          • 106
          thank you
          Good luck!
          hey yeah mine has the early regulators. thanks for your input, i will try an get some
          • Imran574
            • Dec 2013
            • 11
            e30 regulators are the best for use in cars.
            • kingston
              • Jun 2010
              • 2669
              I have a set of the early model coupe manual window regulators. I was going to install these on my car when I started converting it for track use, but I ended up converting my sedan instead. LMK if you are interested in the regulators. They are brand new, never used.
              Cheers
              #teamross
              • bmwstudent
                • Sep 2011
                • 1364
                Especially e30's
