Charge (battery) light randon upon startup - why?
    84' eta
    Every now and then I get the charge (battery) light at startup. I also notice that the lights are dimm at the same time if they are turned on. I can also hear the fuel pump running at a lower pace. As soon as I blip the throttle the charge light turns off, lights get bright and the fuel pump runs at normal pace (normal pump hum). This random charge light happens randomly, I cannot replicate it. Day time, night time, hot, cold, rain, dry, on Mondays... you get the point.
    What I've done - Main, fuel pump, and O2 relays have been replaced in the last month. New fuel pumps. Brand new voltage regulator. Alternator belt is correctly tensioned.
    Battery is of an unkown age, Interstate brand. Engine cranks fine with no signs of a weak battery.
    Any ideas?
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
    Sort of normal. Revving the engine helps 'excite' the alternator into charging. Prior to that, you're just running on battery power. I've had this phenomenon with a few cars of the 70s-80s that have Bosch charging systems. My race car does this every time I start it.
      That could well be worn brushes (which can be replaced) in the alternator.
        Same here, race car does the exact same thing (also have abs light and what not on until i blip the throttle) but charges fine always at 13.8
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          I guess I'll live with it then and monitor for any changes in behavior. It only does it about once out of every 10 or so startups.
          90 325i DD/Track
          03 Durango 5.9
            Follow up on this thread. The issue got worse with the cold weather. Classic sign of battery problems. I replaced the battery 3 days ago, all is well so far.
            90 325i DD/Track
            03 Durango 5.9
