When I bought my 89 325is, I had trouble getting the shifter into 1st gear even when the car was completely stopped. I'd usually first go into 4th first, that made going into 1st a lot easier. I was told the synchros might be going bad and I didn't do anything about that. Soon after that, I had Service Inspection II done and the transmission fluid was replaced with Redline synthetic. After that, going into 1st was much easier, but only when the car wasn't moving. However, when the car is moving at any speed (ie, even 5 mph), I can't get the shifter into 1st even if I rev-match. I drove my uncle's 87 325 for comparison, and his shifter is free to go into any gear granted they're rev-matched.
This is annoying because when I'm going at a crawling pace, I'd like to go into 1st, but instead have to settle for 2nd (ie, rolling stops are a pain). At 5 mph, that means sub-1K RPMs. I've actually had to brake completely once just to start off in 1st again. :( Some add'l info: there is very little side-to-side play of the shifter when in gear so the shifter bushings are probably still good. And even though it's easier getting the shifter into 1st gear when the car is at a redlight after the Redline fluid, it's still even easier when I shift into a higher gear first (ie, 4th --> 1st).
Does this mean my tranny needs to be replaced/rebuilt if I want full function of 1st gear?
