I just replaced my brake light switch today and now all my lights work! The only issue I have now is the light on the warning panel stays on until I press the brake and goes off for good it only comes on when I start my car, is it possible the car takes time to recognize it or did I put the switch in wrong and maybe it has to be adjusted? It's an original bmw switch.
Brake light.
That normal for the panel to do that. Once you step on the brake it sees the amp draw from the brake lights and knows they are working.sigpic -
Thanks for the help, I was just worried because the light never came on before when I started my car this just happened yesterday when my brake lights went out and replaced the switch today and now it comes on when I start the car and goes away. Do you know if the light will eventually go away before and during start up once it realizes the connection is good?Comment
