Well the car I got from my bro has lots of issues and one is the speedometer turning on and off. I'll hit a bump and it'll work perfectly and then it'll go out again. From what I found, it's the differential speed sensor (where can that be found on the car?) but at other times it works like this: I'm driving and the MPG needle goes to 0 and when I let go of gas, the needle goes to the top. at other times, the rev needle works only.
I'm pretty sure the whole "cluster?" (I'm assuming that's the whole speedometer section) was swapped before and I have a bunch of wires under the steering wheel exposed.
Does someone know if it's the sensor (I'm 80% sure it's that) or if the wiring is wrong? Also explain the right terms of the pieces please, if you wouldn't mind. lol. Thanks in advance.
EDIT: Also, I just recently had the oil changed and the coolant is half full but the lights up top are on and sometimes the break light is on too, but everything is fine. My engine check light is on, but the timing belt was done recently and there aren't any noticable problems with the car... This is a wiring failure too?
