I finally had enough of my fuel gauge dancing back and forth and bought a new sending unit for the left (drivers) side of the tank. I thought it would be a straight forward part swap, but now the needle won't move from the dead position. No dancing no nothing now. It's a VDO unit, did I mess something up or can they come faulty from the factory?
Faulty fuel sending unit?
The gauge sitting at the empty end says that there is an open or high resistance in the level sensor circuit. That can be in the cluster, the wiring, or in either sensor on this car as the left and right sensors are wired in series.The car makes it possible, but the driver makes it happen.
Originally posted by jlevie View PostThe gauge sitting at the empty end says that there is an open or high resistance in the level sensor circuit. That can be in the cluster, the wiring, or in either sensor on this car as the left and right sensors are wired in series.
A level sensor will read ~59 ohms when right side up and ~0 ohms when upside side down. So it is easy to test the sensor when it isn't in the tank. On this car you may need to test bot sensors if the first looks okay.The car makes it possible, but the driver makes it happen.
